v2.9 video capture matrox mxo2 max mini
  • FUENTES
    by FUENTES » Fri Jul 10, 2015 3:01 am
    I have no video input at all in this new version, i use a macbook pro and the matrox mxo2 max mini video capture card. never had a problem before until os x Yosemite update
    I found the update to use matrox mxo2 on Yosemite and it work for matrox ventura capture software.
    when I go to the preferences/video capture in module8 v2.9 I get the FaceTime hd camera and matrox mxo2 mini on the options, when i choose matrox or FaceTime the settings options is greyed out. any body with the same problem or knows a solution ???? thanks!
    pele2010
    Re: v2.9 video capture matrox mxo2 max mini
    by pele2010 » Thu Jul 23, 2015 7:37 pm
    Hi , i am having the same problems
    Matrox MXO2 LE with max
    HDMI Input set
    Frimware 36.10
    Software : 4.6.0.0006
    Modul8 2.9
    Macbook 17" (end 2011)
    OSX 10.10.4
    I can´t get any input if its a camera or something else.
    Most bizarre is that the driver is shown in the presets of modul8 and quicktime
    In quicktime i have a yellow triangle with a >!<
    Does anybody have a MXO2 that runs ?
    thanxs
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
