trace has stopped working!
  • mowgli_uk
    by mowgli_uk » Sun Jun 04, 2006 11:34 pm
    recently my "trace" function has stopped working. Whenever i move the knob with the mouse or a midi controller it bounces back to 0 .
    Any clues about what is causing this? It used to work normally until now.
    Cheers.
    by boris » Mon Jun 05, 2006 1:29 am
    Do you have installed some modules ?
  • mowgli_uk
    by mowgli_uk » Wed Jun 07, 2006 1:10 am
    I have tried disabling all the modules to no avail.
    by boris » Wed Jun 07, 2006 5:15 am
    What is your version of modul8 ?
  • V[]LT_yob
    by V[]LT_yob » Thu Jun 08, 2006 5:51 pm
    Is there a chance you've recorded something (inadvertently or otherwise) with the Global Logical record? Whatever the "status" or settings of the Master section were when you starting recording, it will return to those settings when the record bit loops back to the beginning.
  • Akira
    by Akira » Thu Jun 08, 2006 6:37 pm
    I'm getting the same issue. Will try Beta 3
  • jm302
    by jm302 » Sun Jul 09, 2006 3:28 am
    Just wanted to add that Trace hasn't worked for me in any of the 2.5 betas (I assumed it was left out because you gents were still working on it). If that's not the case then something is definitely amiss.
    Cheers,
    Justin
    http://www.302acid.com
  • Akira
    by Akira » Tue Jul 11, 2006 7:43 pm
    Yup, still not working.
    Could it be a PowerPC issue?
    cal6n
    by cal6n » Tue Jul 11, 2006 8:30 pm
    Akira wrote:Yup, still not working.
    Missing on MacBook Pro too
