BlinkyTape Tutorial ?
  • StudioPolygon
    by StudioPolygon » Fri Aug 14, 2015 6:57 pm
    Hi All,
    i got my blinkytape controllers yesterday, but i don't get it running with madmapper.
    Can somebody explain me (and the public) how to check it, or how to do it, how we get it running.
    do wie need madrouter ?
    May be in a little video - ore some sentences. That would be great!
    Thanks and Cheers
    Mathias
    aktion
    Re: BlinkyTape Tutorial ?
    by aktion » Fri Aug 21, 2015 10:39 am
    Buy me some blinky tape and I will make a video tutorial for you :)
    AKTION STUDIO
    by mad-matt » Mon Nov 23, 2015 6:37 pm
    You don't need MadRouter. If you have MadMapper 2.1 or later, you can directly control it from MadMapper, example:
    - Patch your fixtures on ArtNet universe 0
    - In Preferences / DMX Output, choose ArtNet, network interface "localhost" (just not to pollute your network), and check the option "Route ArtNet to LED devices" => a new table appears, there you can press the + button to add a mapping from ArtNet universe 0 to the blinkytape.
    Is that clear enough ?
    Cheers,
    Matt
