Gamma settings not saving
    colabs
    by colabs » Sat Aug 22, 2015 9:26 pm
    I've noticed that my edge blends are not looking right after saving, closing and reopening Madmapper. I've discovered the Gamma settings are always defaulting back to 1.8 after a reload, even if they were saved at a different value. Any one else had this issue? Fix or workaround?
    Anthony Diehl
    colabs
    Re: Gamma settings not saving
    by colabs » Wed Aug 26, 2015 10:57 pm
    Just checked this again in the new release of 2.0.1 and it still does not save. Additionally, you can not store Gamma settings in preset pages. So Gamma is essentially a non-savable parameter. Please fix this guys. The work around I have now is to literally manual write down gamma settings and manually reset them to the correct values when opening a file...
    Anthony Diehl
    by mad-matt » Mon Aug 31, 2015 9:48 pm
    Thanks for your report. It wil be fixed in 2.0.2 release, soon !
    Cheers,
    Matt - MM team
