MiniMad uses?
  • digitalsuperfun
    MiniMad uses?
    by digitalsuperfun » Sat Aug 29, 2015 3:26 am
    Has anyone else been using the MiniMad?
    What have you done with the device? I have enjoyed playing with it, though for now a big limitation is that it will only map triangles and non-deformed quads (3 or 4 points only).
    1) For the developers, are there any plans to allow mesh warping in a future version of software so the MiniMad can do more complex shapes beyond 4-point planes and boxes?
    2) For users, what have you been using your MiniMad for?
    Cheers,
    Ian
    Re: MiniMad uses?
    by franz » Mon Aug 31, 2015 9:36 pm
    of course there are plans to update the minimad feature set ...
    Re: MiniMad uses?
    by franz » Thu Sep 24, 2015 11:47 am
    @digitalsuperfun: do you have any personal examples where you use mesh warping ?
    to us, it seems that mesh warping (esp. bezier warp) is a well under-used feature
Users browsing this forum: No registered users and 85 guests
