minimad update
    lego_man
    minimad update
    by lego_man » Fri Oct 09, 2015 6:16 pm
    How can I update the Minimad image to be compatible with madmapper 2.1?
    thanks
    Re: minimad update
    by franz » Sat Oct 10, 2015 8:57 pm
    launch mad mapper 2.1
    insert your minimal sd into your laptop
    menu -> export to minimad
    in the export box, you'll be asked if you want to update the minimad
    et voila !
    lego_man
    Re: minimad update
    by lego_man » Sun Oct 11, 2015 12:11 pm
    As you can see, the update button is not enable...
    Capture d’écran 2015-10-11 à 12.09.43.png (103.1 KiB) Viewed 12444 times
    Re: minimad update
    by franz » Mon Oct 12, 2015 9:41 am
    I think you version is really too early, before we implemented the update mechanism.
    Re: minimad update
    by Pierre Guilluy » Mon Oct 12, 2015 2:33 pm
    Indeed, early versions of the miniMAD came with a version that wasn't meant to be updated through MadMapper.
    I just sent you the link to the latest disk image so you can flash your sd-card with it.
    From there, you will update your miniMAD directly through MadMapper.
  • kool carlos
    Re: minimad update
    by kool carlos » Sat Nov 21, 2015 6:13 pm
    I've got exactly the same problem.
    The minimad is not updated and the update button is not enable in Madmapper...
    I don't know where find the latest disk image for flashing the minimad's SD card.
    Please help...
    Re: minimad update
    by franz » Sun Nov 22, 2015 3:30 pm
    please contact the support by email they send you a step by step
  • pierolr
    Re: minimad update
    by pierolr » Fri Jun 16, 2017 12:26 am
    I have 4 Minimad, I have to send a new file to a remote installation, but I can not use a new micro sd, can you send me an image to format a new card and send it? Thank you.
    Re: minimad update
    by franz » Tue Jun 20, 2017 5:39 pm
    sure, please contact the support by email, they'll send you a step-by-step.
    sorry for the inconvenience.
