Hap videos play very slow
  • alex specs
    by alex specs » Tue Oct 20, 2015 1:14 am
    i am trying to play some Hap rendered files (640x480 from the Hap sample pack) but they are very slow.
    I run modul8 on a MacBook Pro (Retina, 15-inch, Mid 2014) and its quite impossible to use Hap rendered files on my show.
    is there anyone else experiencing the same problem or has any good tip on how to overcome this problem?
    (every time i try to play one of the samples on Qt it converts before i am able to see it. Could there be a problem with my hap installation?)
    thank you in advance
    Alex
  • alex specs
    Re: Hap videos play very slow
    by alex specs » Wed Oct 21, 2015 12:47 pm
    is it only me facing the problem? i am starting to panic a bit... Friday is my gig .....
