Three video files playing in Sync?
  • rurik2000
    by rurik2000 » Wed Oct 28, 2015 10:01 pm
    Hello
    I'm importing three video files, each one assigned to a quad, each quad assigned to a projector.
    However I need these three clips to play in sync....
    Is that possible? Or do I need some kind of external module?
    Thanks
    Re: Three video files playing in Sync?
    by franz » Fri Oct 30, 2015 1:00 am
    the easy way is to make one video file containing the 3 files: always in sync !
    the other way is to map the same control to the start of each movie.
    by mad-matt » Wed Dec 09, 2015 5:55 pm
    if you don't use audio track, you can also pause the three movies and assign an OSC control to the movie position (OSC supports floating point so it's precise, if using MIDI, even a High Resolution MIDI controller is only 14 bits => you would have frame precision if your movies is less than 16384 frames long, so 9 minutes at 30 FPS)
    cheers
