PJPEG videos drifting out of sync over time
  • rurik2000
    by rurik2000 » Fri Oct 30, 2015 9:41 am
    Hello
    I'm using a MacMini with a decent SSD to ouput to three projectors. My media is 1280x720, PJPEG 80% quality, which seems fine for the machine to handle.
    However as the show repeats over the course of a few hours, the outputs start drifting...
    Any hints as to how to avoid that?
    Thanks
    Re: PJPEG videos drifting out of sync over time
    by franz » Fri Oct 30, 2015 11:39 am
    are your videos exactly the SAME frame numbers ?
    SAME FPS ?
    How do you start them ?
  • rurik2000
    by rurik2000 » Fri Oct 30, 2015 1:01 pm
    Yes, I realized that there were a few frames of difference, my bad...
    I launch the videos by mapping keyboard controls to them...I stumbled upon that functionality by chance, thankfully, as I was about to explore some OSC driven external control :)
    by franz » Fri Oct 30, 2015 7:35 pm
    you need the EXACT SAME frame numbers and frame/persecond replay value.
    Then they should stay in sync.
    To be sure, your best best is still to make one movie with your 3 movies pre-sync'ed
Users browsing this forum: Google [Bot] and 16 guests
