Madmapper 2.1 Crashes when I want to save.
  • Kenneth Danielsen
    by Kenneth Danielsen » Wed Nov 04, 2015 6:19 am
    Hi guys
    About every sekund or third time I want to save does Madmapper crash I use a bunch og special DMX fixtures and I'm trying to adress them all about 300 to 600 fixtures divided on 16 universes. This is a big issue since I was surposed to use this for a big installation but now it takes me more than a hole day if not more since I have to do the same work 2, 3 times again and again.
    I also can't send you the Crash log since you made it so that the crash log works with the mailsystem of mac which I'm not using..
    What can the problem be and can it be fixed.. I'm thinking of just switching and use my Arena 5 for fixtures as well but that brings in a lot of other issues..
    Hope that it gets bette and or there is a solution.
    Best
    -Kenneth
  • Kenneth Danielsen
    Re: Madmapper 2.1 Crashes when I want to save.
    by Kenneth Danielsen » Wed Nov 04, 2015 9:23 am
    I have found that it happens if I erase any of my placed fixtures so my solution at the moment is to move them out of my workspace and give them an unused dmx adress
    by mad-matt » Wed Dec 09, 2015 5:52 pm
    That's weird. Can you reproduce it with MM 2.2.2 ?
    If yes can you PM me your project file so I try to reproduce / fix it ?
