MiniMad Suggestions
  • bLackburst
    MiniMad Suggestions
    by bLackburst » Wed Nov 11, 2015 3:26 am
    Hi
    Can the MiniMad please support alpha for .png's? It looks like it currently doesn't.
    Also, could the "input mesh" points be available for manipulation? By this I mean that i have a 3*3 quad, with the input mesh points moved around, I would like to move these with the minimad controls.
    Thanks
    Re: MiniMad Suggestions
    by Pierre Guilluy » Fri Nov 13, 2015 12:04 pm
    It's noted, I will take a look at that for the next version.
    You can tweak the input points by connecting an external USB keyboard prior to powering the miniMAD on, and type C to enter the cropping edition mode.
  • bLackburst
    by bLackburst » Tue Nov 24, 2015 12:39 am
    Thanks for the tip regarding the cropping mode, but that's not exactly what I was referring to.
    Imagine I create a quad that is 3*3 (for example). I then edit input mesh to move these points around to create a shape different to a quad (a hex for example). I am then usually able to grab these hex points in the output, but with minimad I am still only able to manipulate a full quad. It is pretty unique to madmapper and is a feature I would like to be able to replicate with minimad.
    by franz » Tue Nov 24, 2015 11:22 am
    mesh-warping is not YET supported.
Users browsing this forum: No registered users and 76 guests
