MM 2.2 dmx output mad- 10.10.5 - enttec dmx usb pro mk2
  • Alexander
    by Alexander » Fri Nov 13, 2015 5:23 pm
    Hi Peoples,
    this is my last try to figure out what is going on with my Software/Hardware setup.
    Simply, my Enttec is not coming back to MadMapper DMX output. It was working fine two weeks ago.
    What i did so far:
    - checking/ installing driver FTDI, enttec shows up in the system profiler
    - terminal check with page 15 http://www.ftdichip.com/Support/Documen ... AC_OSX.pdf was good
    - reinstall everything again, madmapper also
    - Arena is able to run the enttec device, Millumin also, MM2.2 not
    - installed helper 2xx, nothing changed
    any ideas?
    thanks, alexander
    results:
    151114_:
    terminal request
    kextstat | grep com.FTDI
    153 0 0xffffff7f8313c000 0x7000 0x7000 com.FTDI.driver.FTDIUSBSerialDriver (2.3) <134 39 5 4 3 1>
    Re: MM 2.2 dmx output mad- 10.10.5 - enttec dmx usb pro mk2
    by mad-matt » Fri Nov 20, 2015 11:45 am
    Hi Alexander,
    MadMapper uses the VCP driver installed natively in Mac OSX. I suppose Millumin is using D2XX. Both driver cannot run at the same time.
    There is an application to switch driver: http://macdownload.informer.com/ftdidrivercontrol/
    I suppose it will solve.
    Cheers,
    Matthieu - MM team
    PS: for fast support use our support system ;-)
