Sync problem with MadMapper 2.2
  • nlecaude
    by nlecaude » Fri Nov 13, 2015 5:25 pm
    We have a project that involves 4x 1920x1200 videos in MPG2 format.
    We want to fill a 4k screen with those 4 videos. The problem we encouter is that when we try to playback those videos, they will de-synchronize quite fast. I assigned keys to stop/play/rewind so I could start them all at the same time but they won't keep in sync. Is this to be expected ?
    Re: Sync problem with MadMapper 2.2
    by franz » Fri Nov 13, 2015 5:41 pm
    MPG2 cannot guarantee you a stable framerate - it might vary -
    If your videos need to be in sync, I'd recommend compositing them all on one movie file, export in HAP or h264
  • nlecaude
    by nlecaude » Fri Nov 13, 2015 7:05 pm
    Ok thanks.
    Had to switch to using Watchout instead of Madmapper for this specific project, no issues with sync with the latter.
    Will pre-render the whole 4k videos in the future if we need sync with Madmapper.
    by franz » Mon Nov 16, 2015 12:19 pm
    pre-render is a solution.
    however, at least you should ensure that your videos have the exact same frame numbers, and FPS, and use HAP (10.10 minimum) or H264
