audio delay in MM2.2.x
  • PhaseIN
    by PhaseIN » Fri Nov 27, 2015 5:44 am
    Hi!
    I,ve some installations that needs video with audio. There's a problem with MM2.2.x - video soundtrack plays with extending delay - it's not synchronized with picture over time.
    Trying on MBP 15 retina (2012) internal soundcard or external NI Audio4DJ – same result.
    Older Version (1.7.x) works perfectly.
    What am i doing wrong??
    Re: audio delay in MM2.2.x
    by franz » Fri Nov 27, 2015 1:09 pm
    what codec are you using ? resolution, audio format, os version ...
    did you contact the support ?
    by mad-matt » Wed Dec 09, 2015 5:42 pm
    1.7 was using QuickTime for playing back movies. MM 2 might behave differently depending on the file encoding.
    You can try reenconding your file.
    Question: does the checkbox "Use hardware acceleration" in media details helps ? It then uses Apple AVfoundation movie playback.
  • PhaseIN
    by PhaseIN » Fri Dec 11, 2015 4:16 pm
    mad-matt - thank You!!
    «use hardware acceleration» button solved problem!!
    i'm using OS X 10.11.1 El Capitan
    codecs usually: H.264 + AAC
    video resolution usually about 2048x768
