Automatic start patch for a museum
  • vento303
    by vento303 » Sun Nov 29, 2015 12:38 pm
    Hi super guys!
    i have to leave a mac mini in a museum, that every morning have to start the installation, in the most automatically way is possible.
    i setted up that mad mapper auto open when the mac is logged in, but i don't find where to say "open last project when mad is turned on", or something like.
    please can you help me? thanks a lot
  • vento303
    auto solved
    by vento303 » Sun Nov 29, 2015 5:34 pm
    hi everybody
    i solved how to open a determined madmapper file automatically at startup.
    under mac's Preferences, go to User and Groups, there's a page called Login Elements,
    where you can just drag in you madmapper file and it will auto-open at startup!
    yo
    Re: Automatic start patch for a museum
    by sigmasix » Mon Nov 30, 2015 4:51 pm
    If madmapper happens to crash during the day you're f**ked… Or someone has to reboot the mac…
    We use an applescript to check if madmapper is open or not and reopen the file if the case of a crash.
    You can find it here http://www.sigmasix.ch/apps/applescripts.html
