MadMapper 8K capture and mapping - possible?
  • vuzak
    by vuzak » Wed Dec 02, 2015 12:01 pm
    Hi there,
    I´m working on an installation where we´ll probably need to capture an 8K signal, and map it over a bunch of projectors. The "bunch of projectors" part I´m fine with, but I don´t know any solutions to capturing an 8K texture.
    Syphon? Capture cards and a Datapath x4 in front of the cards?
    Is it even possible in MadMapper?
    Alternatively "forget it, mate, you´re off yer nut". Any input/ideas are welcome!
    // darkitechture.com //
    Re: MadMapper 8K capture and mapping - possible?
    by franz » Wed Dec 02, 2015 1:44 pm
    no 8k capture.
  • vuzak
    by vuzak » Thu Dec 03, 2015 5:43 pm
    Thx, Frz :)
    It might be that we can reduce the amount of projectors and go down to 2x 4K captures. Like the BlackMagic UHD Intensity Pro 4K cards. I guess that would still need testing :)
    Best,
    Pekka
