by hubavad3r » Sun Dec 06, 2015 3:44 am
hello and thanks for trying to help me out. so i was following along with the tutorial and where it asks to "Create lines from visible edges" i do and if you look at the screen shot you can see my problem. the new layer is the wrong size. i have tried to resize but, fail. i should also mention that i am trying to do this while i am plugged into a 1085t BenQ projector. if i follow the tutorial without my MBP plugged into the projector everything works fine. any help would be appreciated. thank you
- Screen Shot 2015-12-05 at 7.59.04 PM.png (175.56 KiB) Viewed 3696 times
