MIDI Triggering
  • nqeldridge
    MIDI Triggering
    by nqeldridge » Tue Dec 08, 2015 2:46 am
    I am trying to trigger the Play Forward button on a video by a MIDI note. Yet, for some reason, I often have to send the note twice before the video plays. Does anyone have an idea as to why this happens and what I can do to make the triggering more consistent?
    Re: MIDI Triggering
    by mad-matt » Wed Dec 09, 2015 5:37 pm
    I remember something has been fixed in there. Which version are you using ?
  • nqeldridge
    Re: MIDI Triggering
    by nqeldridge » Tue Dec 15, 2015 11:28 pm
    I can confirm that it happens in the latest version 2.2.2, and it happens on different machines.
    I am running El Capitan, not sure if that makes a difference.
    Re: MIDI Triggering
    by sigmasix » Wed Dec 16, 2015 2:08 pm
    maybe your controller has toggle buttons?!
    Re: MIDI Triggering
    by mad-matt » Thu Dec 17, 2015 1:43 pm
    Do you send a MIDI note off between two MIDI note on ?
    If you send a MIDI note ON (with velocity != 0) MadMapper remains the current value of this note, if you send it again, it will not considered you pressed the key again. You need to send a note off inbetween.
  • nqeldridge
    Re: MIDI Triggering
    by nqeldridge » Fri Dec 18, 2015 3:29 am
    I've tried several different solutions.
    My goal is to use Ableton to send the MIDI notes to MadMapper. Ableton is sending a note on and then a note off and yet it does not trigger the video. Then I stop the track and start it over and the video triggers.
    But the problem is not necessarily limited to Ableton. If I plug in my MIDI keyboard, I have to press the mapped key twice before the video will trigger.
    It is the strangest thing. I may have to give in and put in a support ticket with the MadMapper folks.
    Re: MIDI Triggering
    by mad-matt » Fri Dec 18, 2015 10:47 am
    What version of MM are you running ?
  • nqeldridge
    Re: MIDI Triggering
    by nqeldridge » Mon Dec 21, 2015 8:16 pm
    MM 2.2.2
    Re: MIDI Triggering
    by mad-matt » Tue Dec 22, 2015 3:37 pm
    If you map your MIDI notes to /medias/MyMovie.mov/select your media will be applied to selected surfaces (like in this video): https://www.dropbox.com/s/krb7x43e2dxrk ... t.mov?dl=0
    You can select surfaces using the control /surfaces/MySurface/select or surfaces/MySurfaceGroup/select
    You can also use the control that is on each surface to change the media of a specific surface or surface group: /surfaces/SurfaceName/mediaNumber. This can be driven by a MIDI CC.
    Let me know if you have any problem
    Matthieu - MM team
  • nqeldridge
    Re: MIDI Triggering
    by nqeldridge » Tue Dec 22, 2015 9:06 pm
    That solution seems to work. I only need to use one video per song, so I can send a MIDI note to apply the video to the surface right as the song begins.
    Thanks for the help on this!
Users browsing this forum: Baidu [Spider] and 52 guests
