Midi control surface size
  • blutaz
    by blutaz » Mon Dec 14, 2015 7:08 am
    Hi all,
    I'm projecting a circle surface and I'd like to change the size of it in real time with my midi controller. There is any possibility to control the size of a surface through midi?
    thanks,
    b.
    Re: Midi control surface size
    by mad-matt » Mon Dec 14, 2015 9:37 am
    Of course, since MadMapper 1.6, you can just open the "Controls List" from menu Controls. There choose the tab MIDI, press the "+" button on the left, in the popup menu, choose surfaces/Triangle 1/ scale. Then you'll just have to choose the MIDI event to use to control it (press the Learn button and turn your knob)
  • blutaz
    by blutaz » Mon Dec 14, 2015 4:42 pm
    Thank you so much!
    I didn't find it before...learn button is amazing :)
    best,
    blutz
