Not hearing Audio
  • splork
    Not hearing Audio
    by splork » Mon Dec 14, 2015 8:00 pm
    I have searched for an hour or so but can't seem to find anything relevant. I have created my first madmapper projector and movie by creating a 3d image of my house and than adding images and video clips onto different locations. I create the .mov file using syphon, however I do not hear any of the sound which goes with the movie clips.
    Do I need to enable something or do the sound with a different program?
    Any advice would be greatly appreciated.
    I have checked to make sure that the sound is not muted, that the original video clips do indeed have sound, etc.
    Re: Not hearing Audio
    by mad-matt » Tue Dec 22, 2015 3:34 pm
    Are you using MadMapper 2 ? In this case you have to enable audio in the movie settings (below the media list).
    If it doesn't help, does enabling hardware acceleration help ?
  • splork
    by splork » Tue Dec 22, 2015 5:15 pm
    That was it, I knew it must be something simple as toggling something!
    Thanks a ton, its greatly appreciated!
