2.9 Effects inactive- HELP!
  • CateBlanchardDesign
    by CateBlanchardDesign » Tue Dec 22, 2015 4:59 pm
    Hi All,
    Module current version 2.9 working fine since El Capitan update- however i seem to have lost all control of the pixel effect and contrast, lightness, luma key, blur, noise etc?
    i can switch these on and adapt them but any dial movement has no effect on image been projected out Modul8?
    anyone else experiencing this? what can i do? all software is up to date?
    many thanks,
    C
    cansik
    Re: 2.9 Effects inactive- HELP!
    by cansik » Thu Feb 18, 2016 2:44 pm
    Yep, same problem here. It works if you use the CPU to calculate these effects. So I think it is an opengl problem (maybe the shaders)?
    cansik
    by cansik » Fri Mar 11, 2016 4:10 pm
    I solved the problem with simply install the newest version. Even if M8 always told me that it is the newest version, it wasn't.
Users browsing this forum: No registered users and 63 guests
