MAD_Kinect Masker 06a.qtz troubleshoot ! help
    lucianmatei
    by lucianmatei » Tue Jan 05, 2016 3:29 pm
    Hey everyone,
    I want to connect mad kinect masker and madmapper
    I got the Kinect sensor working, but I get this error about the syphon
    > (null)
    <QCNodeManager | namespace = "com.apple.QuartzComposer" | 392 nodes>: Patch with name "QCPlugInPatch:SyphonServerQCPlugIn" is missing
    > Macro Patch
    Cannot create node of class "QCPlugInPatch" and identifier "SyphonServerQCPlugIn"
    > Macro Patch
    Cannot create connection from ["output" @ "Splitter_2"] to ["inputImage" @ "PlugInPatch_SyphonServerQCPlugIn_1"]
    > (null)
    State restoration failed on <QCPatch = 0x7f95f6e65070 "(null)">
    I have copied all the files from SyhponQC to the library Quartz plugins folder..
    Am I missing something?
    Any help apreciated. Thanks.
    I use this configuration:
    MacBook Pro (Retina, 15-inch, Mid 2015); 2,5 GHz Intel Core i7; 16 GB 1600 MHz DDR3; AMD Radeon R9 M370X 2048 MB
    Xcode 7.2
    Quartz Composer Version 4.6.1 (151.2)
    Madmapper 1.7.2
    Kinect xbox360 1414
    Lucian Matei
    VIDEO ARTIST / VJ
    Mobile: 004 0728 513 868
    Web: http://www.lucianmatei.ro/
    manoly
    Re: MAD_Kinect Masker 06a.qtz troubleshoot ! help
    by manoly » Sun May 12, 2019 1:42 pm
    I think that you have that problem because you need to install in Quartz Composer the pluggins required.
    light up your space, share the path
    @missvisuales
    by mad-matt » Mon May 13, 2019 12:18 pm
    The Kinect Masker plugin is broken since 10.10 I think. With latest MadMapper we support Kinect ONE but not the old version. The Kinect Masker is natively implemented in the application. We'll write a tutorial how to use it.
    manoly
    by manoly » Tue Feb 11, 2020 9:10 pm
    Hello, have you implemented the tutorial you commented to use kinect one with madmapper? Thanks a lot
    @missvisuales
    by MADben » Wed Feb 12, 2020 10:54 am
