Output to a video file?
  • TracyE
    by TracyE » Sat Feb 13, 2016 11:02 pm
    Is there a way to have MM render its output to a video file?
    Re: Output to a video file?
    by franz » Mon Feb 15, 2016 12:03 pm
    there's no way "out of the box" - we might design a system in the future.
    a temporary workaround is to activate syphon output, and use syphon recorder to capture MM's output in realtime.
    depending on your output resolution and hardware, this might be sufficient for your needs.
    another workaround is to use a second computer with a video capture card such as blackmagic
Users browsing this forum: Bing [Bot] and 10 guests
