MIDI OUT
  • kolemjdouci
    MIDI OUT
    by kolemjdouci » Mon Feb 29, 2016 5:29 pm
    Hello there
    I have one important question..Is somehow possible (via module or through external software) that M8 would send out a MIDI message after a video loop ends.?
    I'm trying to connect M8 with several movement sensors and the notice message about the end of the loop is really necessary to me..
    - any ideas?
    Thank you in advance..
    Re: MIDI OUT
    by sigmasix » Tue Mar 01, 2016 9:53 am
    What do you mean by "end of loop" ? It's possible to know when a clip ends in play once mode. In loop mode it's a bit harder as the received value may not be very precise. Maybe you can be more precise if you check if the time is 00:00:00:00 and send a midi message.
    Using the module editor it's not so difficult. But 'tis not the easiest trick if you never edited a module… I can try it for you if you want
    Re: MIDI OUT
    by sigmasix » Tue Mar 01, 2016 10:53 am
    Ok, did some tests, it's a bit tricky but I managed to do something stable enough I guess.
    You can find a module in the online library called (s6) sendMidiOnLoop
    You'll need to open the module editor to change the midi message. It's this line you need to edit:
    Code: Select all
    modul8.sendMidi(0, 1, 'CONTROL_CHANGE', 3, 127)
    Good luck
Users browsing this forum: Baidu [Spider] and 20 guests
