Stuttering / Juddering when looping around
  • loglesby
    by loglesby » Wed Mar 09, 2016 12:01 am
    I have a wide format video (5440x1200, H265 encoding, 13.1MB file size) that is intended to be a looping background in my project. Unfortunately, MadMapper will judder or stutter to varying degrees whenever the media loops back to the start.
    This is on a quad core Mac Pro with 32GB of RAM. MadMapper does not seem to have any options to tweak for things like ensuring media is stored fully in RAM. Ticking the "Use Hardware Acceleration" box just results in a black preview pane and a black output.
    Can anyone help me understand how I can get around this?
    Thanks in advance.
    Re: Stuttering / Juddering when looping around
    by franz » Wed Mar 09, 2016 4:07 pm
    please encode in H264 if only playing forward, or HAP if playing in any directions.
    Does that change anything ?
    Meanwhile you can contact the support and send them your file for inspection.
  • loglesby
    by loglesby » Thu Mar 10, 2016 10:12 pm
    Works a treat! :D
    Hadn't came across this codec before (HAP), thanks for the heads up!
