Best LED's for video?
  • Eaglerulez
    by Eaglerulez » Tue Mar 15, 2016 8:10 am
    Hi there,
    I was curious if anyone had recommendations on LED strips that are particularly good for video? I am trying to create what is essentially an LED video wall out of LED tape so I am trying to figure out which strips have a refresh rate and color rendition that many people would fine acceptable.
    Any thoughts?
  • megsmith
    Re: Best LED's for video?
    by megsmith » Mon Apr 22, 2019 8:09 pm
    Maybe you can check out different LED modules with p2.5-32s pixel pitch and 160000 dot/m2. They usually are great use for indoor LED video walls. Here's a comprehensive guide to buying that might help: https://dynamo-led-displays.co.uk/buyin ... d-display/
    by MADben » Tue Apr 23, 2019 8:24 am
    you should definitely take a look at LED by garageCube : http://www.garagecube.com/led
    deisgned by the garageCube team in order to be used with MadMapper!
    there is a contact form on the website (to get the current price list).
