Locked 3 posts Page 1 of 1
ART-NET INTERFACE
  • jureeesh
    ART-NET INTERFACE
    by jureeesh » Thu Mar 31, 2016 9:15 am
    Please does anyone knows which supplier in europe sells ART-NET INTERFACE described in http://www.madmapper.com/controlling-le ... madmapper/.
    Thank you
    http://www.loop-video.hr/
  • Xaver2k
    Re: ART-NET INTERFACE
    by Xaver2k » Thu Mar 31, 2016 10:28 am
    there are so many post in this forum about this and i think you are in the wrong section two.
    it depends about what you want to control, just regular rgb strips or digital strip and so on... the cheapest way is too order from china or take a look on ebay and so on.
    broken
    by broken » Fri Apr 01, 2016 4:42 am
    Wouldn't bother with that unit.. I did the same thing.. scoured the internet for the parts shown (no links to products given) and was a bit of a waste.
    There's much better options out there..
    Instead I built a DIY unit with 2 circuit boards wired in series that had 9 channels on each. I used 12v RGB strips, but not "pixel mapping" ones, all pixels do the same colour.
    Here's the boards I used - http://www.ebay.ca/itm/30CHANNEL-27CH-E ... SwA4dWMdRZ
    If you want to do artnet for pixel mapping though - the parts on the tutorial from garagecube won't cut it.
    I'd recommend something like this box - http://www.ebay.ca/itm/DMX-512-Art-Net- ... Sw14xWLLOt for ws2811, ws2812b, ws2801 strips
