New to madlights (need help for setup)
  • hsh383
    by hsh383 » Fri May 20, 2016 11:22 am
    Hi never use madlights. Regular user of resolume, madmapper, module8
    One of my client want to control led light useing Raylogic LDX-300 http://www.raylogic.in/products/product_led (last product on the list) which also has to be sync with midi notes
    So please can any one tell is it possible using raylogic LDX-300.
    please help me with the processes for the light setup. all i have is Raylogic LDX-300
  • Xaver2k
    Re: New to madlights (need help for setup)
    by Xaver2k » Fri May 20, 2016 3:41 pm
    on the website is written, it can be controlled with DMX512 so it can also be controlled with Madlights! Maybe you need a DMXcontroller like USB->DMX or as i would prefer Artnet->DMX.
  • hsh383
    by hsh383 » Sat May 21, 2016 6:48 am
    Thanks Xaver2k For reply.
    Just a little confusion if i use DMX512 USB->DMX or Artnet->DMX i will be able to use LDX-300 through it (LDX-300 can be use as dimmer )
    for example setup would be like
    Computer running Madmapper - Enttec ODC - LDX-300 - LED STRIP...!
  • Xaver2k
    by Xaver2k » Sun May 22, 2016 3:22 pm
    yepp
