Locked 51 posts
Modul8 v3.0 hd BETA
    Modul8 v3.0 hd BETA
    by boris » Fri Jul 29, 2016 7:51 pm
    The Modul8 v3.0 hd Beta 1 is released!
    Please feel free to use this topic to give us feedback and bug report about the modul8 v3 BETA.
    You can send a mail to : beta[AT]garagecube[DOT]com
    I will send a beautiful modul8 t-shirt to anybody how report and explain how to reproduce a bug or crash (if the issue is new for us).
    Enjoy !
    Boris.
    PLEASE NOTE :
    The team will be on vacation until August 22.
    Please continue to send your reports!
    We will work hard on it to fix everything (and make t-shirts) when we will back from our holidays.
    Thanks for you understanding!
    GarageCube and Modul8 Team is proud to announce the release of modul8 HD Public beta 1 Release.
    Modul8 goes now HD ! The dev team wrote a brand new media player engine, it's fast, very fast and now Modul8 HD can now render up to 8K videos. Forget about Quicktime PhotoJPEG , this new engine was optimized for HAP and H264 codecs.
    We also added useful new features to add comfort for the user experience like a new User interface now compatible with retina display screens. You can now lock a layer to prevent from deleting or editing an important asset of your show.
    Up to 1024 Media
    New 8 Media set groups : you can now handle up to 1024 media in a single project.
    Additional specials testcards: FullHD, HDReady, XGA, WXGA
    Output Lightness
    Useful when you work with LED Walls or create content for MadMapper's MADLIGHT
    Change the brightness of the final displayed output while you keep the output preview untouched
    Modul8 HD Version V3.0
    BETA 1 Release Note :
    NEW FEATURES & CHANGES
    + New super optimized media player engine
    (images, movies, image folders, Quartz-Composer, video-inputs)
    Now supports videos up to 8K
    Optimized for HAP code and H264 video playback
    + user-interface with retina displays support
    + support up to 1024 media loaded (8 mediasets of 128 medias)
    + new Locking and unlocking layer
    + new Master Lightness output
    + new layer normalize ratio options (4/3,16/9,16/10)
    + new automatic Image resizing to use less memory "Image maximum rendering size" preference
    + additional specials testcards: FullHD, HDReady, XGA, WYGA
    + display RGB Color preview for background color, invert output color and output add color, modulate and additive color for layers
    IMPROVEMENT
    * improved Direct to Disk Recording (faster, add feedback informations)
    * Saves video Preview mode when quit.
    * video capture preferences display BlackMagic out-dated drivers warning
    * Disable Blackmagic support" preference for other apps to use it
    * replaced quicktime player by both FFmpeg and AVFoundation for maximum codec compatibility (for multi audio channel video, use AVFoundation playback option)
    * bug fixes and stability improvements
    *Drag and Drop Media import is working with more than 16 media
    New Modul8 Module Keywords:
    ctrl_layer_lock
    ctrl_layer_mediaSetGroup
    ctrl_layer_scale_normalizeOn
    ctrl_master_lightness
    ctrl_master_fadeToBlack
    This Public Beta version is available from today for any users who own a serial which is compatible with modul8 2.9. To download it, click on the button or log on the modul8 yourspace page us gin your modul8 serial
    DOWNLOAD MODUL8 HD BETA 1
    Please test it and send us your feedback and Bug report to support@garagecube.com
    Your feedback is really important in order to improve our Software and provide you the best user experience with Modul8.
    All the GarageCUBE/Modul8 team is grateful for your help.
    WARNING!! : PLEASE DON'T USE IT IN PRODUCTION (OR AT YOUR OWN RISK)
    If you save older project with this beta version you won't be able to open it on version 2.9.2 and older
    Reason: disclaimer about beta use
    Re: Modul8 v3.0 hd BETA
    by boris » Fri Jul 29, 2016 8:22 pm
    I found the 1st issue :
    The module 'syphon input' does not choose the correct media!
    I new t-shirt for my collection!
    by boris » Fri Jul 29, 2016 8:37 pm
    It's fixed there is a new version (1.1) in the online library.
  • anomad
    by anomad » Fri Jul 29, 2016 8:42 pm
    . the beta crashes when I launch on a MacPro 1,1 (original model) 12GB RAM, OS X 10.7.5 - what is the minimum supported hardware / OS level ? :)
  • mocomeau
    by mocomeau » Fri Jul 29, 2016 9:05 pm
    There seems to be a problem with the Syphon Module.
    If I syphon out Modul8 to MadMapper, it seems to take a larger part then what I am sending.
    For instance, if I'm outputting 720p, if I do a simple "Full Screen" output, it goes full. If I output it to syphon and Madmapper, it will take a bigger chunk of output. If I move my image in modul8, I can see it move in the dead space in Madmapper. As if the syphon took larger than it was suppose to.
    The cropping of mad mapper doesn't work because there is a massive lost of resolution.
    I'm attaching a picture. I hope this issue could be fixed soon because I would love to test it on the road !
    ** When troubleshoot with modul8 2.9, Syphon takes the full resolution
    Madmapper_Syphon Windo
    Capture d’écran 2016-07-29 à 15.02.06.png (116.79 KiB) Viewed 30795 times
  • rdpozo
    by rdpozo » Sat Jul 30, 2016 12:07 am
    Seems to be very jittery when playing back hap encoded video files. Tried different hap codecs. jitters/stops in playback.
    Same files work fine on 2.9
    by boris » Sat Jul 30, 2016 12:59 am
    Oh oh!
    Already some issues!
    I think I will do more t-shirt than expected!
    by boris » Sat Jul 30, 2016 1:14 am
    AAScreen Shot 2016-07-30 at 01.08.42 copy.png (1.04 MiB) Viewed 30727 times
    Hi mocomeau,
    Are you sure that your preferences are well adjusted?
    The preferences for the 3.0 are not the same file of the 2.9.xxx, maybe by default is too high, I will check.
    I tested on my computer and it's fine (see the screenshot).
    Boris.
    by boris » Sat Jul 30, 2016 1:29 am
    Hi rdpozo, can you elaborate a bit?
    Your version of OSX, your computer ? (ram, graphic card, hard drive...)
    On my not so new Mac Book Pro Retina (middle 2012, 2.3 Ghz i7, 8GB ram, Nvidia GeForce GT 650M 1024MB, SSD disk) and OSX 10.11 it works like a charm...
    by boris » Sat Jul 30, 2016 1:34 am
    I think we did not tested less than 10.9... :-o
    Maybe that's the minimum...I will check...
    So you win a T-shirt, please send a mail to beta[AT]garagecube[DOT]com with you size !
    by boris » Sat Jul 30, 2016 1:37 am
    I found a crash when you switch between syphon output and desktop if you use the syphon in MadMapper.
    So no t-shirt for this one!
    by boris » Sat Jul 30, 2016 1:44 am
    Hi there,
    But please continue to send your reports !
    Thanks for your understanding !
    Boris.
  • niabarreto
    by niabarreto » Sat Jul 30, 2016 2:39 am
    I am testing Modul8 v3.0 on my old mac (mid 2009 15" MacBook pro, 4GB RAM, with 10.11.3 OSX "El Capitan" ) and so far,so good.
    I am using touchOSC and have different codecs (some PhotoJPEG and H264), and the iSight. I have to say I just do this for testing purposes and have a 3-4 active layer limitation (due to ram, duh), but everything seems to be working just fine, with luma and tracing on and reproducing sound and everything. I haven't tried syphon yet.
    Thanks for the update guys!
  • rdpozo
    by rdpozo » Sat Jul 30, 2016 8:41 am
    Sure Boris,
    Here is the specs:
    OSX El Capitan
    V. 10.11.5
    Macbook Pro (retina 15-inch, Early 2013)
    Prosessor 2,8 GHz Intel Core i7
    Mem 16 gig 1600 MHz DDR3
    Graphics NVIDIA GeForce GT 650M 1024 MB
    Hap QT Nr.11
    Codec: HAP
    Quality: Medium
    FPS: 25
    Size: 1280 x 720
    gmint
    by gmint » Sun Jul 31, 2016 12:16 am
    I used the beta for a show last night and noticed a couple of things. Not sure they really qualify as bugs, but it would be nice to see them both fixed in any case.
    1) (Not new in this version) The state of the fading and scaling crossfader settings are not saved into a composition across restarts. It would be very nice if they were.
    2) If a composition has been saved with modules and those modules are missing (which they were from my beta install at first) Modul8 will open the project but it will continue displaying a "Loading Structures" dialog indefinitely.
    3) For some reason, all of my HAP encoded files have a strange yellowish tint. This does not seem to be the case when I load the same files in MadMaper. I have attached a screenshot. This does not happen with H.264 or other files.
    Screen Shot 2016-07-30 at 5.13.21 PM.jpg (221.95 KiB) Viewed 30549 times
    DJ G Mint
Locked 51 posts
