Locked 2 posts Page 1 of 1
Soft edges
  • LilleLys
    Soft edges
    by LilleLys » Sat Aug 13, 2016 12:09 pm
    Hi!
    Quick and easy question.
    Is there any way to soften the edges of your output? I've seen the whole tutorial for softening edges between different projectors, but I want to soften all the edges out from just one projector.
    Re: Soft edges
    by mad-matt » Mon Aug 22, 2016 12:49 pm
    With version 2.x, you can put a quad on top of other surfaces with an image - PNG with alpha - to have soft borders on a full projector.
    With previous version you can do the same with projector mask, but you won't be able to do perspective on it
