live video input with gopro hero4
  • Catli3
    by Catli3 » Mon Aug 22, 2016 2:19 pm
    Hi
    am trying to feed live image into the mix for a performance. (M8 2.9.2)
    Got a gopro hero4 and a mbp running 10.11.6. and tried the following connections: (unsuccessfully)
    microHDMI into HDMI ...:(
    MicroHDMI into thunderboltport ...:(
    USB to USB ... :(
    I did manage to connect my old DV camera, but I'd like to use the Gopro for a crisper input image.
    ( I did try unchecking the video input : quicktime sequence grabber in the preference panel)
    Any ideas out there to solve my problem?
    cx
  • Catli3
    Re: live video input with gopro hero4
    by Catli3 » Tue Aug 23, 2016 8:28 pm
    anyone with a less pricey solution?
    ]quote]Hello Cat,
    The easiest solutionis using a capture card HDMI blackmagi such as the ulstrastudio mini recorder
    You will also need a go pro HDMI cable to connect to the video card.
    Best Regards,
    Walid | GarageCube Team[/quote]
    by sigmasix » Wed Aug 24, 2016 10:11 am
    that's the way to go…
    maybe you can find a cheaper capture card but it might not be working properly with modul8…
