Newb question: Outputting projects with media?
  • weinventyou
    by weinventyou » Wed Aug 24, 2016 10:35 pm
    This seems like a very basic question but I've been unable to find the answer on the FAQ or in these forums. Apologies if it's been covered already!
    I would like to send my madmapper project to someone else that has the madmapper software. My project is pretty simple: it uses 3 different media (.mov files) and 8 quad shapes. However, no matter how I export the project (Save Project As, Export Output in the File menu, Export Outputs in the Tools menu, Export Fixtures, etc), it never saves the underlying media/.mov files.
    Is it possible to export a project in one, simple, file that includes all the media? Or do I need to just send the project and media files separately?
    Hope that makes sense.
    Re: Newb question: Outputting projects with media?
    by mad-matt » Mon Sep 19, 2016 4:30 pm
    No there's no such option. However if movies/pictures are in the same folder than the ".mad" file, MadMapper will find the medias automatically. So just make a folder with the .map and the movies and that'll be ok.
    Cheers!
