Generate DMX Lines on input
  • bLackburst
    by bLackburst » Thu Aug 25, 2016 4:19 am
    Considering the generative line objects are created on the output window, I can't send them to DMX. Is this right? Seems like led pixels would benefit from generative lines even more than projected output. Is there a way around this or a future feature?
  • Xaver2k
    Re: Generate DMX Lines on input
    by Xaver2k » Fri Aug 26, 2016 3:14 pm
    in my madmapper the lines are displayed in the same field where i map the dmx fixtures...
  • bLackburst
    by bLackburst » Wed Aug 31, 2016 3:56 am
    Oh really? I'm referring to the line surface/media items, not the dmx line fixtures.
    There is madline which can be syphoned in, but in madline you have no reference to the layout of your fixtures. I'd love if it was just me doing something wrong!
    by sigmasix » Wed Aug 31, 2016 11:10 am
    It looks like you need to update your madmapper
  • bLackburst
    by bLackburst » Thu Sep 01, 2016 2:16 am
    I'm running 2.2.6.
    Someone else has the same thing:
    viewtopic.php?f=20&t=9560
    aktion
    by aktion » Fri Sep 02, 2016 7:40 pm
    Yes you are right. You currently cannot do that. as the DMX only is editable in input window. and Madline is only editable in output window. hence they don't overlap. and plus i think Madline interacts in the same way as other media can with dmx.
    I tested it on 2.5 beta 4
    AKTION STUDIO
    by mad-matt » Mon Sep 19, 2016 3:44 pm
    Yes Mad Lines cannot control LED fixtures. There is a tweak for it, in latest 2.5 beta, activate Syphon output and enable MM to show its output in Syphon Inputs. Then use the Syhon output of MM as the media for the fixtures. A bit tricky but it works :-)
