show mad mapper syphon outputs
  • javierbenjamin
    by javierbenjamin » Thu Aug 25, 2016 9:52 pm
    hi-
    i wanna use mad lines for my dmx fixtures. I the new release the say you can send it via syphon inside mad mapper. But the option doesn`t show on my preferences. ( yes , i update my mad mapper version. i use the 2.2.6 )
    i attach the image that shows the option that dosnt show.
  • Xaver2k
    Re: show mad mapper syphon outputs
    by Xaver2k » Fri Aug 26, 2016 3:11 pm
    the 2 activated fields should fine now you should see the madmapper output as an input in the input view
  • javierbenjamin
    by javierbenjamin » Fri Aug 26, 2016 10:06 pm
    yes. The problem is that i dont have the 2 options in my preferences. the don't show
    by mad-matt » Mon Sep 19, 2016 4:28 pm
    We added those options in 2.5 beta if I'm not wrong. The 2.5 release should be in a few weeks. A new beta will be released in the coming days
