Preview Panel Shortcut for GRID-LAYER-.....-OUT
    pele2010
    by pele2010 » Sun Sep 11, 2016 4:24 pm
    when I tested the VJ3 I found that it hat the ability to switch in-between the Preview- VIEWS.
    It would be great if these would have shortcuts by default.
    Or at least we could make shortcuts.
    I can't select them with the "keyword browser" and neither with "keys" nor with "midi" mapping
    they are selectable.
    kind regards Peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • anomad
    Re: Preview Panel Shortcut for GRID-LAYER-.....-OUT
    by anomad » Tue Sep 13, 2016 3:06 pm
    . hey Peter - i came across this issue as well and found you could add a few lines to a module to switch between preview a, b and output…
    . look at ' ctrl_ui_previewWindowMode '
    The current preview mode:
    0 for grid, 1 for layer, 2 for group inv, 3 for group A, 4 for group B, 5 for out mix, 6 for out.
    SET: modul8.setValue('ctrl_ui_previewWindowMode',value,10) GET: modul8.getValue('XXXXXXXXXXX', 10)
    . so, i created a button for 'Preview A' that when pressed executes:
    modul8.setValue('ctrl_ui_previewWindowMode', 3, 0 )
    . and then assign a MIDI or key press to the button
    -james
    (a nomad. )
    pele2010
    by pele2010 » Sun Sep 18, 2016 1:12 pm
    Hey, excellent!
    I will check this
    thanks so much!
    Peter
    #eachfilm01
    #pele2010
    www.eachfilm.de
