powermate USB media wheel
  • visual-hybrid
    by visual-hybrid » Tue Jun 13, 2006 9:52 pm
    hello... similar question to mr collett..
    have just bought a powermate USB media controller...
    its made by griffin and is supported with wide array of soft..
    FCP, photoshop, i tunes....
    trying to get to work with modul8
    any thoughts.. have tried changing the settings and seems very programmable.. but cant get to work...
    any thoughts??
    cheers
  • andras
    by andras » Thu Jul 20, 2006 12:09 pm
    Yeah, sad to experience the same. My biggest problem with M8 - in terms of usability - are the short sliders which are hard to be controlled precisely with a mouse. I thought I would be able to use my PowerMate for this, but I cannot. You can attach "send key: Right Arrow" to Rotate Right, and in this case if you can controll a sider if you want (which would be almost enough for me) but it reacts soooo slowly. The problem is in M8, i guess, as e.g. the slider that changes bw group A and B often does not work perfectly with the Left & Right Arrows on the keyboard, either.
  • trukske
    by trukske » Tue Oct 10, 2006 4:20 pm
    Hello, the same problem. In mdi it isn't possibl either. I'm also searching a external speed slider that is a bit more controllable than the thiny speed slider in modul8. The only option is to try it with an usb device, but i schouldnt know wich one...
