Help with Mad Light
  • blabberbytes
    Help with Mad Light
    by blabberbytes » Tue Sep 13, 2016 12:09 pm
    He so I never used DMX before VIA madmapper / madlight. I'm on madmapper 2.2.2. I have an enttec pro mk2. The firmware is on 4.10. The drivers seem to be installed as I am able to control the lights in PRO-Manager.
    In Madmapper when I go in the preferences I select the enttec device. After this I'm not sure how to get the light to work. I have a dimmer pack and a regular par light. I go in the DMX section and add a fixture. Mad mapper and the dimmer pack are both set to channel 1. After that I am not sure what I'm suppose to do but I tried a bunch of things and I cant get the light to turn on. What actually turns the light on and off? The response fader? Luminosity?
    Also connection wise all I have is the green DMX1 into the input of the dimmer pack along with the usb cable into the computer.
    Any help would be appreciated.
  • Xaver2k
    Re: Help with Mad Light
    by Xaver2k » Tue Sep 13, 2016 4:25 pm
    To turn the light on, you need to put an input behind your DMX fixture like an image, video or some lines and then the color will control the DMX fixture. :wink:
