HAP Q Codec Yellow ?
  • eloimaduell
    by eloimaduell » Fri Sep 16, 2016 1:52 am
    Hi GarageCube and MadMapper's !
    I'm facing a problem playing any HAP Q encoded videos in MadMapper 2.2.6 ...
    Basically my HAP Q frames are somehow tinted in Yellow and some weird alpha transparency.
    I've seen something related to this on a Module8 thread and seemed like not solved for Module8 ...
    Is it solved for MadMapper ?
    Thanks for any advice !
    e*
    Re: HAP Q Codec Yellow ?
    by mad-matt » Mon Sep 19, 2016 3:48 pm
    Yes, Hap Q is not properly supported in 2.5 beta. Please use normal Hap codec until 2.5 final release.
  • jaimechao
    by jaimechao » Sun Jan 08, 2017 3:11 am
    Hi
    it seems that the same problem persist in MM2.5
    I have encoded a video in HAP Q alpha with AVF batch converter and it appears yellow in MM (screenshot attached).
    Jaime
    screenCaptureHapQAlpha
    Capture d’écran 2017-01-08 à 02.05.20.png (113.73 KiB) Viewed 5091 times
    by mad-matt » Mon Jan 09, 2017 11:08 am
    In 2.5.0 final release, Hap Q is displayed correctly but with poor performances. We'll handle it with hardware acceleration in future updates. For the moment, if you need high performances, use Hap, not HapQ...
