Active Module if selected "changed color of the top bar"
    pele2010
    by pele2010 » Sat Sep 24, 2016 10:40 am
    Hey,
    if you have many modules open it´s very difficult to find the one you need after a while.
    Often I have to go over the modules menu and even the it´s very difficult to see the
    slight change in opacity of the top bar where the name of the module is written.
    It would be very helpful if the select module would have a different color, like a dark orange.
    If not selected it changes to blue again.
    Maybe I am the only one that has problems with this.
    But I tend to think a lot about the selecting of modules.
    A search function would also be great.
    What do you think?
    kind regards Peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • MovieBear67
    Re: Active Module if selected "changed color of the top bar"
    by MovieBear67 » Sun Aug 18, 2019 4:29 pm
    Yes please!!
    pele2010
    by pele2010 » Tue Mar 10, 2020 7:25 pm
    Yeah.... My Post is 4 Years old.
    Man time can run.
    One reply.
    Cool. :mrgreen:
    I am going to check it again in 4 years.
    no real layer masking yet. :x
    #eachfilm01
    #pele2010
    www.eachfilm.de
