Possible MiniMad Wish List Roadmap
  • ProjectileObjects
    by ProjectileObjects » Sun Sep 25, 2016 2:36 pm
    The miniMad is already awesome and any of these additions would be cool. (Adding what others have written)
    - Ability to manipulate masks on other miniMAD's in sync from one "master" miniMad
    - Projector control via rj45/ LAN, with on / off scheduling. (Like the PocketVJ)
    ✓/ Raspberry Pi 3 support, miniMad wifi sync, and control with Bluetooth keyboards // The .dmg from yourspace seems to work with the Pi 3 out of the box, but not the 3B+ (latest). No wifi/Bluetooth support yet.
    - Update miniMad video files over a network.
    ✓ Possible MiniMad Artnet control for LED Pixel mapping automation.
    -Device lock and custom passcode for unlock (They way it can only be adjusted by the installer).
    ✓ (added) LED control over Artnet ;) :D
    ✓ OSC Control (Now works with TouchOSC)
    - NDI Support (HDMI over Ethernet protocol for long runs or network installations)
    - TCPSyphon Support (live stream to miniMAD from your computer)
    Last edited by ProjectileObjects on Sun Aug 19, 2018 12:49 am, edited 5 times in total.
  • brendanrbercik
    Re: Possible MiniMad Wish List
    by brendanrbercik » Tue Nov 08, 2016 12:59 am
    These are all great! I just registered in order to reply, adding to the list:
    - TCPSyphon support! So that if need be, VJs / artists / performers could send video via Syphon server over a network (via ethernet, professionals) to the MiniMAD in real time.
    Uploading video files to MiniMAD over a network (preferably with mapping locked in as well) would be great too.
  • kneusteun
    by kneusteun » Mon Nov 28, 2016 5:41 pm
    wifi connection. (pi3)
    PJlink
    OSC
    Those would be awesome
  • h3dproject
    by h3dproject » Thu Jan 26, 2017 4:41 pm
    PJlink
    OSC
    OSC +1
    Wifi +1 (pi2 as well using dongle)
  • TheYouth
    by TheYouth » Thu Feb 23, 2017 3:37 pm
    This can already be done with an normal Raspberry Pi :)
    http://techlife.sg/TCPSClient/
  • Videometry
    by Videometry » Sun Jun 11, 2017 4:19 pm
    it would be sweet for miniMADs to work as remote outputs to a host computer thru TC/spout or TC/Syphon!
    I imagine a situation where you have 1 miniMAD per projector connected on a network with a host computer running madmapper that can stream them content.
    Once you are done with the mapping you could update the miniMADs SDcard thru the ethernet connection and then disconnect the cables (as opposed to removing the card.)
    Loving the miniMAD thus far, thanks for the awesome tools!
  • HugheyH
    by HugheyH » Sun Oct 29, 2017 9:20 am
    Absolutely! That would be great if this was possible. Is there any way to make it happen?
    This testosterone boosters success story is really impressive.
  • balamsoto
    by balamsoto » Thu Feb 15, 2018 6:47 pm
    Masking
    audio reactive
    lines animations
  • ProjectileObjects
    by ProjectileObjects » Fri Aug 17, 2018 5:13 pm
    These are all great responses.
    Thus far they've added
    -DMX Lighting control (artnet sACN, etc)
    -OSC
    TCPSyphon would be great as well. Or even better(?).............. NDI :o
    The NDI advantage is simple, you could also use the miniMAD as an HDMI over Ethernet connection for long runs or networked installs.
