FFmpeg Tools is required - after installed?
    broken
    by broken » Tue Sep 27, 2016 5:13 pm
    Just picked up my miniMAD and tried to export a quick test map from Madmapper 2.5b5
    It throws up a dialog saying:
    "FFmpeg Tools is required to export to miniMAD.
    Would you like to download it now?"
    NO/YES
    Selecting YES to download, chrome opens, I download the pkg installer, run it..
    Relaunch Madmapper.. Export to miniMAD and I get the same dialog asking if I want to download FFmpeg Tools..
    Knowing that I just installed FFmpeg Tools from the Garagecube website, I figure I might need a reboot before it can find FFmpeg Tools..
    Nope.. same issue. Can't export because it keeps asking me if I want to download FFmpeg Tools.
    Playing back 1 clip in Madmapper it says Player: FFMPEG Player
    Not sure why Madmapper keeps on asking.. Anyone have a clue?
    Yosemite 10.10.5 hackintosh
    broken
    Re: FFmpeg Tools is required - after installed?
    by broken » Tue Sep 27, 2016 5:39 pm
    Not sure whats up with the pkg installer.
    After a few google searches on how to manually install FFmpeg, I stumbled upon Homebrew - a terminal package manager for OSX
    http://brew.sh/index.html
    installed via terminal command: /usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homeb ... er/install)"
    then ran: brew install ffmpeg --with-tools
    Problem solved, and the Export dialog pops up instead of MM asking if I want to download FFmpeg constantly.
  • emilesteginga
    by emilesteginga » Sun Oct 23, 2016 3:50 pm
    I have the same issue with the latest version of madmapper.
    I tried the homebrew you described but that did not work.
    How to proper install FFmpeg Tools? anyone?
    / edit: finally it did work by using the instructions on this page:
    https://trac.ffmpeg.org/wiki/CompilationGuide/MacOSX
    by Pierre Guilluy » Thu Oct 27, 2016 10:23 am
    Please check the existence of ffmpeg binaries in /usr/local/bin/ through the terminal:
    # ls /usr/local/bin/ff*
    If the FFmpeg installation went well, you should have:
    /usr/local/bin/ffmpeg
    /usr/local/bin/ffplay
    /usr/local/bin/ffprobe
    /usr/local/bin/ffserver
    If those files are missing, MadMapper will keep asking for FFmpeg binaries installation.
