Unanswered Spatial Scan Issue
  • Galatrose
    by Galatrose » Wed Sep 28, 2016 7:00 pm
    I am using
    Madmapper 2.2.6 Serial 2B6L-xxx-xxxx-xxxx-VYKG
    with a late 2015 iMac 5k with 32 gigs of ram.
    Running Osx 10.11.8
    with a USB Tethered Canon t6i set on S2, small jpeg 1080x
    Projector attached via HDMI
    When I launch spatial scan I get the dialog that shows the camera and projector attached as seen. When I run the scan, an error window appears saying that I must use jpeg and not camera raw,etc. I have looked up this on the forums and the solution is to upgrade the Mac OS and the version of MadMapper, as both are up to date, what do you suggest I do?
    I have seen this issue on numerous boards and no resolution.
    M
    broken
    Re: Unanswered Spatial Scan Issue
    by broken » Thu Sep 29, 2016 1:48 am
    uhhh.. remove your serial unless you want to share your license with the world
Users browsing this forum: No registered users and 63 guests
