Garbage in the preview
    broken
    by broken » Thu Sep 29, 2016 8:08 pm
    Having issues with some of the test cards displaying static or garbled images when clicking on them the first time.
    If I click away to another clip and back, the correct test card is displayed. Noticed this happening a bit in the last beta as well.
    Screenshot 2016-09-29 14.01.12.png (57.46 KiB) Viewed 7166 times
    Screenshot 2016-09-29 14.01.03.png (45.85 KiB) Viewed 7166 times
    broken
    Re: Beta 3 released!
    by broken » Thu Sep 29, 2016 8:09 pm
    the other 2 test card shots I grabbed
    Screenshot 2016-09-29 14.01.31.png (53.86 KiB) Viewed 7165 times
    Screenshot 2016-09-29 14.00.36.png (58.14 KiB) Viewed 7165 times
    by boris » Thu Sep 29, 2016 8:15 pm
    Oh oh
    Already a feedback !! great !
    Looks like garbage, could you test-it with output Retina?
    In the preference (Misc--> Retina)
    Of course we don't have that issue here...
    Also what graphic card, os, etc... are you using ?
    For the next time to make things simpler please create a new topic.
    Thanks.
    Boris.
    broken wrote:the other 2 test card shots I grabbed
    broken
    by broken » Thu Sep 29, 2016 8:20 pm
    boris wrote:Oh oh
    Thanks.
    Boris.
    Cheers Boris,
    Sorry for replying here - some of my other topics posted outside official posts don't seem to get much notice so I thought this might be my best option to get a reply!
    The Retina setting has seemed to fix this garbage static. Thank you for the quick response! I must have missed the addition of the Retina feature.
    edit: 10.10.5 using a NVIDIA GTX 780 6GB VRAM
    Re: Garbage in the preview
    by Pierre Guilluy » Mon Oct 03, 2016 2:50 pm
    Hi Broken,
    Are you using a Mac Pro with a GTX 780 installed on it?
    According to your screenshots I assume you're running Modul8 on a non-retina screen?
    Could you try to deactivate the Retina preferences and give Modul8 another try to make sure it's the cause of the issue?
    Pierre
    broken
    by broken » Tue Oct 04, 2016 6:18 pm
    Pierre Guilluy wrote:Hi Broken,
    Pierre
    I am using a self built "hackintosh" with GTX 780 installed.
    The screen I have attached in the screenshots is 1680x1050px resolution.
    The fix was actually to activate the "Retina" preference as boris posted above, and I confirmed in my previous post.
