Syphon maximum size
    melting
    Syphon maximum size
    by melting » Mon Oct 03, 2016 8:31 am
    What is the maximum pixel size we can send over from modul8 to madmapper via Syphon ?
    pele2010
    Re: Syphon maximum size
    by pele2010 » Thu Oct 06, 2016 9:34 pm
    I am not shure, but I guess it depends on your machine?
    I just tested 4K and this works.
    I also tested 8K but my machine slowed down . And my madmapper got slow.
    I work with a macbook 15" from 2015.
    there is a dialog field where you can enter the numbers.
    Under > Modul8 >preferences >Misc > "syphon output size"
    And there you can put in your numbers.
    But not everything you can do makes sense.
    so I hope this helps
    peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    melting
    by melting » Wed Oct 19, 2016 6:40 pm
    thanx,
    my projection surface ratio outputed in madmapper is 720x2580
    what i want to do is send to madmapper one surface which can makes 2 times 720 x 2580,
    means 2 modul8 channels to handle live to use in different surfaces in madmapper
    with a reserve, means something like 1450x2600
    anyway, it works, so everything is fine ;)
    mpol
Users browsing this forum: No registered users and 68 guests
