1080p only? No WUXGA
  • Gilbert
    by Gilbert » Thu Oct 20, 2016 6:26 pm
    MiniMAD is projecting via WUXGA. Before exporting the Projection and Settings tabs are set to 1920 x 1200 - I'm also exporting with "parameters of selected projector".
    Projection has a 1080p red border - assuming that this is the limit?
    Re: 1080p only? No WUXGA
    by Pierre Guilluy » Wed Oct 26, 2016 11:03 am
    1080p is indeed the maximum resolution supported by the miniMAD (the export dialog shouldn't let you input greater values than 1920x1080).
    As a test, I've just tried exporting a 1080p project to a WUXGA screen, but I can't see any red border, as the monitor vertically stretched my 1080p to fill the screen.
    Could you send a picture of the problem on your side?
    Anyways, I agree it's a problem MadMapper doesn't warn the user it's not capable of displaying the "Parameters of the selected projector" and I'll definitely fix that in the next version.
