change the input of an preset ?
    pele2010
    by pele2010 » Mon Oct 24, 2016 12:53 pm
    Hey,
    if I have made a set up and I have generated many presets ( 1,2,3,4)
    then these presets repair to position, layer form , media , etc.
    But if I would like to change the input (media) of preset 1 without changing it´s
    scale , position , etc. , how can I do this?
    How can I only change the input of a preset without losing the other information
    of the preset.
    Is there a clever way to do this?
    I was writing this post while I was testing the presets in madmapper;
    then I found one solution to my initial question.
    But I am not sure it it´s the only one so I post a tutorial here:
    https://vimeo.com/188640977
    I hope this helps Peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    Re: change the input of an preset ?
    by pele2010 » Mon Oct 24, 2016 1:34 pm
    Hey,
    you can select all quads at a time and change the input:
    https://vimeo.com/188645219
    peter
    #eachfilm01
    #pele2010
    www.eachfilm.de
    by mad-matt » Tue Oct 25, 2016 10:50 am
    Pressing Cmd + media assign button (with left arrow) will assign the media to ALL surfaces.
    You can also make groups of surfaces. In this case if you assign a media while a group is selected, it will assign the media to all surfaces in this group.
    pele2010
    by pele2010 » Tue Oct 25, 2016 7:15 pm
    Hey mad-matt,
    in german we say "da freu ich mir ein Loch in den Bauch"
    which means: I please myself a hole in my belly....
    :lol:
    Which basically means that I am very pleased!
    thanxs a lot .... this app is an endless adventure.
    Next month I am scratching the light surface.....
    best peter
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    by pele2010 » Tue Oct 25, 2016 9:58 pm
    Hey mad,
    I am not sure, but with the arrow left right I can select different ISF material
    and with cmd click I can exchange the complete material.
    it´s great and very quick.
    excellent, thanxs for the tip ...
    #eachfilm01
    #pele2010
    www.eachfilm.de
