output problem
  • outtersea
    output problem
    by outtersea » Tue Oct 25, 2016 1:38 pm
    my macbook pro system is macos10.8.5, + Modul8V2.8
    detail : 2.3 GHz Intel Core i7, 8 GB 1600 MHz DDR3, Graphic card Intel HD Graphics 4000 512 MB
    Problem description:
    A projet has been saved in Modul8, but when it's re-opened in Modul8, all medias in MediaSet and setups work well except the output window show nothing. even i add new layer and new media, the output always rest empty.
    furthermore, i ve try recreate another new file in Modul8, output work well in the new one, but after i saved the file, it doesn't work as the file is re-opened, output show nothing again.
    thanks for your help
    pele2010
    Re: output problem
    by pele2010 » Tue Oct 25, 2016 7:31 pm
    Hey,
    could be many things!
    1.to me sometimes it happens that the preview window is set to "outmix" or "group B"
    and when I change this I can see the media again.
    2. Lasst time my Master Alpha was down to 0% and I did´t look at it
    3. Sometimes a Module I installed is interfering with the project. So you should go to >modules>stop all.
    4. And then I had a corrupt project that I managed to >File> export with media. And after reopening
    everything worked fine again.
    5. And last but not least I make a restart and try it again.
    6. If this does not help and the project is not to big maybe you can transfer it to the support?
    its: support(at)garagecube.com
    I hope I could help.....
    I admite it´s pretty scary if it happens, even more scary if you are pre checking a show and full
    with adrenalin.
    So I hope everything works fine for you and wish you the best ....
    peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
