Minimad Build version downgrade
  • gnomalab
    by gnomalab » Tue Oct 25, 2016 2:40 pm
    minimad build
    I opened for the first time minimad card in the beta version 6 madmapper. works all right, I'm delighted. the problem now is that the version madmapper.2.2.6, tells me I need to update. Is there any way to downgrade to use the latest official version of madmapper?
    Re: Minimad Build version downgrade
    by Pierre Guilluy » Wed Oct 26, 2016 10:52 am
    Version 2.2.x didn't let you downgrade miniMAD.
    The solution is to trash the "app" directory that's in the MINIMAD partition and let MadMapper reconstruct the directory with the corresponding version.
    Starting with version 2.5, MadMapper will allow you to downgrade miniMAD's version.
