micoSD size/limits?
    broken
    micoSD size/limits?
    by broken » Mon Oct 31, 2016 6:08 pm
    Was wondering if there's an easy way to create a new microSD for miniMAD that's larger than the supplied 8gb card?
    I've used Apple Pi-Baker to create duplicates of the 8gb SD, but I'm trying to see how far I can push these boxes with content and curious about using larger SD cards.
    I've got a 16gb SD that I tried with Apple Pi-Baker but it only appears as a 8gb disk when writing the image saved from the 8gb card (obviously), leaving the other 8gb unpartitioned/unused.
    I think I remember reading about contacting support for info about using bigger cards, but couldn't find the posting again so I thought I'd just ask here in hopes that others have the same queries
  • mohsann
    Re: micoSD size/limits?
    by mohsann » Wed Nov 30, 2016 10:19 pm
    after you write the image you've got to resize the "mapping" partition
    os x can't resize it in disk utility so you have to use terminal
    taken from this thread on macrumors:
    http://forums.macrumors.com/threads/edi ... ap.872009/
    1) Do a Get Info in Disk Utility on the drive you want to modify to obtain its Disk Identifier, which will probably be in the form diskn, where n is a small single digit.
    2) Also using Disk Utility, back up the volume (partition) you are going to modify (if it has anything you want to save on it) by creating an image file of said volume. If there are any other files or volumes on the disk that you really, really don't want to risk losing, back those up also, just in case!
    3) Open Terminal and type
    Code:
    fdisk -e /dev/<disk identifier>
    where '<disk identifier>' is the name you obtained in step 1. Ignore the message:
    Code:
    fdisk: could not open MBR file [...]
    that you will probably then see.
    4) Type
    Code:
    p <RETURN>
    to see a list of partitions on the disk. Then type
    Code:
    edit <n>
    where <n> is the number (from 1 to 4) of the partition you want to edit, which had better be the last one on the list of partitions unless you are knowledgeable enough not to have needed these instructions in the first place. You will be given a sequence of prompts that you can respond to by pressing <RETURN> to choose the default. However, if you don't want to use up all the space at the end of the disk for the partition you are expanding, you can respond to the 'Partition size' prompt with a smaller number. In addition, if the default response to the 'Partition offset' prompt is a lower number than the existing start sector number for that partition, you may want to respond to the prompt with the latter number, so that the starting location of the volume remains unchanged.
    5) After you do this, type 'p' again to make sure that you haven't changed any other partitions, then type 'w' to write the new partition table to the disk. Despite any warnings you will see before confirming this, writing the edited partition table to disk will not change anything except the partition (volume) whose entry you edited, and, in most cases, won't change any data even on the edited volume, although the OS may, when that volume is mounted, treat it as unreadable or problematic. In that case, you may want to restore the contents of that volume, or some part of them, from the backup you made in step 2.
    I just did this last night for a 32gb disk for my minimad and it worked great.
    broken
    by broken » Wed Nov 30, 2016 10:29 pm
    mohsann wrote:I just did this last night for a 32gb disk for my minimad and it worked great.
    Beauty details & explanation, will give this a shot tonight :)
    thank you!
  • mohsann
    by mohsann » Thu Dec 01, 2016 10:08 am
    I forgot to mention...
    After you resize in terminal
    You need to erase your "mapping" partition to make the new space usable.
    Use Disk utility for this. Backup the contents of "mapping" and copy them back after you've erased the partition.
    broken
    by broken » Thu Dec 01, 2016 6:25 pm
    mohsann wrote:I forgot to mention...
    Cheers for this --^ haha
    I know I was able to change the partition size through fdisk but it wasn't being fully used until it was erased and made use of the new space.
    Madmapper sees all the extra space now :)
    I may grab a few different size cards and make up some images for ApplePi Baker so nobody has to mess with fdisk or terminal to use larger capacity cards
  • buckrogers999
    by buckrogers999 » Thu Jan 17, 2019 1:08 pm
    have you found a size limit.
    thinking of buying some 64gb cards
