No modules in macOS sierra 10.12.1
    melting
    by melting » Wed Nov 09, 2016 8:12 pm
    Got my brand new MAcPro with MacOs sierra 10.12.1
    No modules at all in MD8 !
    I can download them, but they are not safed , so everytime i open MD8, they are disappeared !?
    melting
    Re: No modules in macOS sierra 10.12.1
    by melting » Wed Nov 09, 2016 8:43 pm
    ...same for Modul8 V2.9.2 !
    by Pierre Guilluy » Fri Nov 11, 2016 3:35 pm
    Next week's beta will fix the problem.
    Please PM me for a intermediate build if you can't wait ;)
  • EyesInAxis
    by EyesInAxis » Wed Dec 21, 2016 10:53 pm
    I've got the same problem but my problem is I'm on tour with Modul8 and I need my modules to be stored when i back up my projects. I can't waste my time to download and set each one every time I'll start my project.
    Is V3 HD betas only solution to fix this ?
    thanks !
    by Pierre Guilluy » Thu Dec 22, 2016 9:46 am
    We've patched the official Modul8 2.9.2 to be compatible with macOS 10.12.
    Please download it again from YourSpace and you should be ok.
  • EyesInAxis
    by EyesInAxis » Thu Dec 22, 2016 11:03 am
    I'm gonna try
    Thanks very much !
  • Lichtfaktor
    by Lichtfaktor » Wed Jan 11, 2017 1:55 am
    I have the same problem even with the patched 2.9.2 Version on El Capitan.
    When it starts it doesn't show up any modules. It is also weird that when I click "About Modul8..." it does show that it's the educational version - even though I did update the registration information.
    Is there any solution on this?
    Many thanks,
    Jens
    by Pierre Guilluy » Thu Jan 12, 2017 10:58 am
    Hi, I've just tried downloading official Modul8 2.9.2 from YourSpace on El Capitan (10.11.6) and I can see/use all modules at startup.
    Could you try trash your current version of Modul8 (don't forget to backup your own modules before) and download it again?
    You can also remove your preferences by pasting the following line in the Terminal:
    defaults delete com.GarageCUBE.modul8_25
  • garageRoot
    by garageRoot » Fri Jul 14, 2017 9:36 am
    Ensure that you don't run Modul8 form the DMG archive . sometime when you firstlaucnh modul8 when downloaded you run it form the archive and after you create a short link to the dock. Modul8 cannot write modifications on the .dmg archive
